Onza T-rex Bb Help
balfa
Just got a Onza T-Rex and in the process of fitting the cranks.
I'm using a square taper BB 128mm Axel and middleburns with a 22T chainring. The problem is there is no way the chainring can clear the chainstay!
I don't believe a longer BB is availible in square taper.
Is this setup impossible?
Any options short of getting the super pro/heatsink bash?
Hmmm. I've got the same set up but I'm running a 20T chainring. I've never tried a 22T on, so don't know whether there's enough clearence for one or not. You could maybe try a 20T chainring with a different sized sproket/cog at the back to keep the gear ratio the same.
Only problem with that is I have a 18T Freewheel on the rear so i'd then have to buy a 16T freewheel.
I'm confused because I'm preety sure I got my Middleburns (22t) before I snapped my factory BB so I'm preety definite it does fit on.
But anyway now on my T-Rex im running the 127.5mm Echo/VP BB and I can garuntee its long enough. Echo/VP BB
Phil
Don't do that! 22 - 18 is the best setup for a T-Rex in my opinion.
