Vw Polo Fuel Problem
hI-OOPS-CAPS
I have a '95 polo 1litre,
as i was coasting along i saw the rev needle drop to zero and it didnt start when tried straight after.after some things were tried,i put petrol in and it fired up straight away.at first i just thought the petrol needle wasnt reading right as it was 1/4 tank
low and behold same happened again, after fillin it up 25£ of petrol, i drove maybe 10miles and bam,my engine cut out for same reason.
im not sure if petrol needle is workin correctly,but im pretty sure it is.i cant smell petrol either.
any ideas of what the problem is??
when its running, does it drive well? any lack of power?
im guessing its only wanting to cut out if you leave it to idle?
it runs with normal power, and by needle i mean the needle that indicates the fuel in the tank.it has fuel injection
it cuts out when it isnt in gear,when it idles
just went back to car with petrol (bearing in mind it fired up straight away when i put petrol in the previous time) and it didnt start.
is there any sort of fuel filter? or any place a blockage can occur?
hmmm, might not be a fuel problem atall. could be spark related.
although saying that, the fact that there is no loss of power indicated that the fuel and spark are being provided.
possibly your idle contol valve is faulty.
possibly the wires and connections that connect the idle control valve are faulty!
i remember on my vw golf mk3 1.4 (different engine i know) the temp thermostat was locked closed, which meant my engine always was overfuelling, which was ok when driving, but when idling it would bog down with fuel and stall. but i dont reccon this is your problem as you've said you can't smell fuel.
hope this helps, let us know how it goes
i think wills got it right there (Y)
hm now i dont think its fuel related.both times this problem happens,it started afterwards when its been left alone for about 1hr 30mins or so.
before that when i try and crank it up the engine will just turn but wont start.will a faulty idle control valve stop it starting after it cuts out??
think im gonna splash out a tenner on a fuel filter and keep my fingers crossed
contradiction? lol
no lack of power suggests nothing wrong with fuel delivery!
contradiction? lol
ah no i meant fuel as in fuel content of the tank. because twice it started when i put fuel in, but those 2 times it had been standing for like 2hrs.
when i mean fuel filter, i did ask "or any place a blockage can occur?" because it cant really be much else
its not a vacuum
its not a vacuum
ok man only trying to help.
did you try taking the fuel cap off and starting it like someone mentioned?
yeah i know sorry, its just quite frustrating when it works when its cold, then when ive done like 20miles itll cut out and i cant start it before its stood to lets say 'cool off' for 2hrs
yeah tried fuel cap.didnt work
