Helicoil Need Help
sam D
i am thinking of swapping my frame, but the frame i am swapping for has been heilcoiled how bad is this word. as when it comes to selling the frame people react to it like it has aids just wondering if someone can give me some advise. ie... how long will it last cheers sam
Edited by sam D
Yea I recently stripped a couple of threads on my Echo frame, at first I shat myself at the thought that I had.
But I took it to a local motorbike engine specialist where he then helicoiled it for me.
The steel insert is much stronger than an alloy one, so they should be done as standard.
Also if you do manage to strip the coil insert itself, its a matter of taking it out and putting a new one in.
It won't be long until my other 4 bolt holes go, but its for the best.
Helicoiling is the way to go.
so why does it put people off the bike so much ?
thanks for all the help so far
cheers sam
People probably prefer to buy something as original as possible whether it be modified for a better result or not, the mindset being less original = old and bastardised. I would happily buy a frame with helicoils in it but would try tightening bolts into it first to make sure everythings right.
I put a helicoil in my Adamant the other day and it works great and also was surprised how neat it looks.
It's about £25 for the kit to do it yourself, which comes with the tap, helicoil inserting tool, and 10 inserts. Takes less than 5 minutes to do each mount, so if you're mechanically minded you should be able to do a whole rear end in about 15-20 mins.
