My Stock 26" Bt Raven 8.0 Vertical.
EranFuld
I've finally completed my Stock 26" BT Raven 8.0 Vertical project:
Frame: Stock 26" 135mm BT Raven 8.0 Vertical length: 1072mm, chain stay: 379mm, BB: +20mm
Fork: Cannondale Fatty R
Handlebars: Adamant Riser Bar 740mm
Stem: Kore 110mm 6 deg
Rear Rim: Alex DX 32
Front Rim: Rhyno Lite
Rear Tire: Maxxis Mobster 2.5
Front Tire: Maxxis Minion 2.35
Rear Brake: Magura HS-33
Front Brake: Avid BB7 185mm
Cranks: Truvativ Holzfeller ISIS
BB: Truvativ Gigapipe DH
Bashguard: Pilo 22T
Rear Hub: Surly
Rear Freewheel: WhiteIndustries 20T
Front Chainring: MiddleBurn 22T
Front Hub: Formula
Booster: Echo 4 Bolts
Pedals: Wellgo A52 Platform
Is that Surly rear hub eccentric like ENO's , or did you fine tune chain tension with clever selection of sprocket sises / witchcraft ? Either way , good looking , though unorthodox bike .
Thanks I find them incredibly special as well :-)
No eccentric hub just a 20T->22T ratio that allows having no chain tensioner at all.
Cheers,
-E
