Sh*t Brakes
D A N N Y
Hi, all i just wonderd how i could make my brakes better i was doing gaps earlier and my brakes kept slipping and i fell off 3 times :sick: in the space of about 10 mins and i just wonderd what are the pros and cons of tar or a grind.
Many Regards
Danny
1st. What pads do you have?
2nd. You may need to bleed your brake.
Grind- They wear down pads faster and are needess in the summer/dry times.
A brake set up consisting of a smooth rim and the correct pads can be as good as a set up with a grind.
When it happens to be wet, they are lifesavers.
A grind also impares the life of your rim.
I have onza stock pads dont think that helps much :lol: and the brakes are fine i dont think they need bleeding can any one recomend some good pads on a smooth rim thanks.
Many Regards
Danny
Edited by D A N N Y
Plaz Spanish Fly pads.
Amazing smooth rim pads.
Threw me over the handlebars many times!
LoL.
Ok you have helped lots thanks
Many Regards
Danny
P.S What are the plazmatic crm's like on a smooth rim ?
By the way i am using on back rim so i need somthing that can hold good on the back wheel
Edited by D A N N Y
surely when using tar it doesn't really matter what pads you use?
To an extent yes, as pretty much any pad grips using tar.
However, with Deng pads such as the Echo's I use have quite a tacky feel on a smooth rim without tar (where-as with a harder pad it just slips).
Therefore I only need to put a small tad of tar on my rim just give it a bit of lock.
When I used standard magura blacks the pads really stuck to the rim, good hold but not good when you want to quickly let the brake off.
Many Regards
Danny
They're quite good,
Not as good as Spanish Flys though.
As they are amazing!
I don't agree with that. You can get good braking on a smooth rim but for a brake which relies on friction, a grind will always improve performance.
And as mentioned above, Cousts are great for smooth rims even though they're super hard.
Many Regards
Danny
yea get some crm's they are awsome on a smooth rim even without tar.
edit: wrong danny haha
(Y)
Edited by TOBY-E
There amazing, but because they were so good at holding on to the rim they ripped out of the backings :giggle:
and yeah. i never used tar on them. but that was with rear mounts on the front.
Smooth rims are great (I ran one with Rock Green pads for a while) - roll through some damp grass, hit a puddle wrong or cycle in even the lightest of rain and you might as well not have brakes at all. Don't know about anyone else, but that completely ruined my confidence in smooth rims for trials, so I'm now on a harsh grind with Superstar red pads. Loads of noise (Which I'd rather not have) and it holds every time, wet or dry :).
I don't think grinding really affects rim life unless you do a lot of grinding - I grind my rims possibly 3 times a year (If I'm riding a lot) and still have never replaced a rim through it being worn out. When I used rim brakes for XC I'd wear through the braking surface of a rim in about a year, thanks to the brakes being dragged rather than used to lock the wheels and mud making very good grinding paste. I've only once worn through a trials rim and it took at least 3 or 4 years...
