How To Reduce Brake Noise ?
davey90
Hello, i,m having a bit of a problem with the noise coming off my rear magura. Set up is Hs33 Raceline, Standard Hoses, Evo Mounts, A Mahoosive brake booster,Red Superstar Pads and a smooth Sun Mammoth Fat rim.
Problem is that its rediculosly noisey, every curtain twitches and heads turn as i roll down the strret with my break squealing like an pig in labour. Is there anyway possible of reducing the noise without changing the pads, as they work amazing.
. . my breaks are SO loud and i love it , its your braks way of letting you know there working . . . . .. .
. .you could try stop using your back brak when you don't have to ,that's what i have done
Edited by gogz69
I fitted a brake booster and my back brake is silent
However when I used to run two maguras on my mod, I preferred a loud back brake and a quiet front brake, so I could use the front one just for riding. It also meant that it would offer more modulation, so front wheel moves would work, only I never did them on it, lol.
