Band Brakes!
JT!
Got a tricycle here with one of them on it, it's crap. Anyone got any ideas on how to make it better?
Or if not, anyone know where i could get a replacement one with a much grippier surface.
Thanks!
Do they feel particularly spongy?
They usually have quite a rough surface from new, then once that's smoothed itself out, it'll be good and you'll be able to set the brakes up even tighter.
EDIT: However, they are just generally shit.
setting them up 'tighter' isnt going to make them more powerful.
if the lever feel is very hard, then i'd suggest that you change the cable, see how it is, and then look at a way of changing the leverage ratio.
it'd be a good idea to clean them up and make sure they arent contaminated also!
Didn't say it would, but it will make they nice feeling brakes.
I didn't think of changing the leverage though... Good point. Also, better levers like Avid SD7s adjusted for most leverage and less cable pull could help a lot.
So tar wouldn't help then. :P
I'd rather not fiddle with making it more powerful mechanical wise because the brake is very very spongey as it is. I've pulled a lot of cable though and it has a decent bite point, but it really is useless.
