Onza Cleaner
TrialZonn
Hey!
Some photos from my first trials bike!
FRAME:Onza Cleaner 26''
FORK:Onza
STEM:Onza
HANDLEBARS:Onza Alloy Oversized Bars
GRIPS:Giant MTB
FRONT WHEEL:Onza Wide Double-Walled Rims on Onza Disk Hub
REAR WHEEL:Onza Wide Double-Walled Rims on DMR Revolver Fixed Hub
FREEWHEEL:Tensile Optimum Freewheel
REAR BRAKE:Magura HS-33 with 4-bolt Tensile Brake Booster
FRONT BRAKE:Onza Mechanical Disk-Brake
BOTTOM BRACKET:Onza Square Taper
CRANKS:Onza Armstrongs
PEDALS:Onza Shin Dig
TIRES:Onza Sticky Fingers (2.10 Front,2.50 Rear)
Many thanks to the Tartybikes team for their help and support!!!
Comments welcome!
looks nice that :) but to be honest looks very heavy at the front and middle and abit to strong
Yes you are right.The bike weights around 11.5-12kg.It was heavier when I bought it but I saved some weight by going to singlespeed.If I'm not mistaken the forks are steel.
The weight is not a problem for me because I ride only urban and want my bike to be strong.That's why I bought the Tensile brake booster (no holes,but the strongest out there)
I think that the weight doesn't play a significant role when you are learning a move.And as a begginer rider I'm still learning...so I think I would go with lighter parts later.
The frame is one of the strongest out there too if I'm not mistaken (it's the evolution of the t-rex)
Thanks for the comment!
that actually doesnt look half bad, but i still reckon the MADs are the best beginner bikes atm
I could go with the phase 1.1 as the price is very close to the Onza Cleaner but I prefered the Onza:
I believe the Onza's frame is much better...hydroformed downtube,3 tubes welded with the BB which means a stiffer and stronger frame.
As for the components...they have not so many differences.The only difference I noticed is that the phase has maguras front and rear,Shimano components and undrilled rims if I'm not mistaken.
I liked the look of the Cleaner much more so I decided to buy it.
I have not ridden a MAD so I don't know if it's better.You know much more about trials brands and bikes though for sure (My bike it's the only trials bike I have ridden :lol: )
Thanks for the comments
