Rear Disc Adaptor
Captain Scarlet
Would not work on a trials bike as looking at the design the only thing that holds the adapter to the frame is the force of the brake whem slowing the bike down forwards, if you were to rol backwards the adapter would just move!
Adam
What stops it rotating upwards? It's probably only designed for XC bikes so they won't have to deal with backwards forces aswell as fowards.
Good find though. (Y)
EDIT: Le Bigfellow, he is too fast!
Edited by Muel
Yeah but would you trust it?...
I dont trust rear discs So We Will Never Know.
What about if you drilled ahole in the adapter for where the screw goes for the snail cams and put a longer one in so the mount wouldn't move ?
You Would Loose all rear Wheel Adjustment. And You Would have to Pretty acurate when Drilliing the Hole.
You could Slot it, but then its Useless if you have a Stock
