Hs33 Pads To Work On Dead Grind?
Connor Powell
Hi guys,
Basically ive bought a try-all rim and i know grinds dont last long on them and i dont want to grind it too many times and make the sidewalls thin, i want this rim to last a while so ive been thinking about running some pads on a dead grind, atm i have coust sinks which dont work on a dead grind. So what have you guys tried that work on a dead grind possibly with a little tar, I did run heatsink snowys before on a dead grind but im not sure if they've changed the compound.
Anyway, Fire away :D
Thanks.
Edited by Connor Powell
I think you should just regrind with a harsher angle. Have the grinding disc at a 70-90 degree angle to the rim, press hard and go fast. Makes a really deep grind, and it lasts ages, even on softer rims like try-alls. I haven't ground mine in 2.5 months and it's still not dull.
