Help With Pad Choice
CC12345678910
Heres the deal. Which pads do I choose:
1) heatsink pads (any, I'm not sure which to pick)
2) Atomz Pads in powerpad backings (cheap option)
3) Atomz Pads in Heatsink backings.
I'm using an 05 spec maggie with a less than perfect oil bleed (I'm gonna sort that though), deng lever blade, a smooooth onza ronnie rim, no booster and original Zoo! pads (which are suprisingly awful) @ the moment.
EDIT: I am NOT going to get a grind.
Edited by CC12345678910
Rock greens. So so so sticky. Best pad I've ever used and have performed brilliantly on my stock and 24. They're designed for smooth rims as well, as opposed to all the other pads people seem to be reccomending.
Rock greens are gash, zoo plaz and snowies are were its at.
Mat
Word. Rock greens are amazing on an echo anodized rim. Just don't use them in the wet, as with all smooth rim setups though.
