Bash Plate On A Stock?
Ezg_Cannuck
Hey guys,
I was just wondering if it's possible to: 1) find a bash plate with geometry designed for a stock bike
2) if such a thing exists, but my bike doesn't have mounts for a bash plate, is it possible to custom fab?
You see, I'm worried about denting/cracking my frame on the down tube when I miss...as i'm a heavier rider. Any help would be great.
Cheers
Edited by Ezg_Cannuck
If your frame doesn't have mounts for a bashguard there is still the option of making a custom guard with aluminium grip plate and a few jubilee clips... Trials frames are designed to take the odd knock on the downtube anyway, so unless you routinely hit the downtube or want to keep your frame pristine you're pretty unlikely to break the frame doing this...
Like Ben originally said old Trex.
I have an old t-rex frame with bash plate mounts.
unfortunately i lent it out for a bit and they managed to damage the bb threads so you coulds have it for 20 quid? its quite short which is lovely for streety trials but i dunno. if your interested PM me
some frames have plates on the downtube to prevent dents etc my monty (stock) had a plate covering the lower 2/3rds or 1/2 of downtube which was pretty good
unless your tryin rails or really pointy natty chances are you wont catch your down tube very often anyway
A cheap downtube protector can be manufactured from a section of old tyre with the wire bead cut out and some thin aluminium sheet (1-2mm thick should be sufficient). Position the length of tyre on the underside of the downtube, overwrap it with the aluminium and clamp it all up solid with jubilee clips. Should stop the majority of dents but not weigh excessive amounts - when the aluminium gets ragged just replace it and jobs a good un :)
Cheers for the advice from everyone. Now just out of curiosity, does anyone think it would be possible to drill holes and tap them so a plate could be mounted? ...hypothetically
Where would one get thin aluminum like that? Preferably for a decent price. haha
You'd remove far too much strength from the downtube. At the end of the day it'd do more harm than good.
The BB shell or possibly chainstays would be the only places where the frame might be thick enough to take enough screw threads to hold a bash guard firmly. Putting a hole in a plate under tension roughly triples the peak stress (If I remember my stress concentration factors correctly) in the part even if the screw hole doesn't significantly change the area of material supporting the load. Jubilee clips are the way to go as these don't require you to modify the frame at all... Who'd have thought that this was a valid website: http://www.jubileeclips.co.uk/ :)
