Magura Brakes
after some loong thinking i have decided that an onza rip is a good choise for me, affordabel and upgradable,
but it has vee brakes, and i wanted to fit magura H33's on the back,
is there an adaptor kit?
and if there is is it good or a bit of a compramise?
and is there anywhere you can recommend getting it from,
cheers
Edited by edwradmark91
kl :) cus i have mountain biked, and i always kept my brakes rock solid, so the slightest tap and i was nearly over the bars, and i got kinda found of it, so i want it to carry on, and i have been told brakes like this are the best for trials :)
thanks again :)
xxx
thanks again :)
xxx
Yep, you need good brakes which will lock up instatly. :)
can vee brakes be similar in power and modulation to magura's? or with the right pads?
xx
vee brakes are stronger that magura hs33's but they can be a faff because they take abit of time to setup right and the wire stretches due to the tension but if you can get them right they are betterer ;)
Edited by Nickkkkk
yeah i have a horrendous time with cables, cus i always break the caps off the end by accident and end up cutting my hands on the frayed ends :( so the idea of getting magura hydraulics which it says need minimal maintenance, seemed immense :) but if they wont fit on the onza rip, i will just stick with cables :)
xxx
To be honest I think you would be much better off getting yoursel the onza bird instead of the rip because the bird has a 19" back wheel and will be stronger and more suitable parts etc. On the subject of brakes I too agree that a vee brake with the right pads can be as good if not better than a magura.
xxx
But, magura can he a alot worse then cable's for maintainance. :P
Hello again get magura's if you get them new they come with all the parts you need to fit on to standard v mounts in the box all mine did so double check with the shop to make sure ok mate.
okay :) so magura brakes can fit on a 20" bike, and they do come with adaptors for vee mounts :)
but i know that they can get expensive, but if they are really as good as i have been told then i think they are the best option :)
thanks alot guys :)
happy riding
cheers
IF you havn't bought the rip yet pay the extra 50 (is it 50?) for the Onza pro, it has a 19" backwheel which will be alot better and would eb able to convert to Maguras :)
Keep the bike as it comes new take off the rear brake system and the disc rotor, put on your magura you will need some 4 bolt mounts to done.
P.S. Thats if you get the 09 onza pro
Edited by Earl
