Trial Tech Cranks
Luke Williams!
So i finally fitted my trialtech cranks after f**king the first ones up by using the wrong bash (my bad) but i bought a set with the trialtech bash half ring set up! and an 18 tooth screw on front ring!
i made sure it covered the necessary amount of thread as to not f**k them up this time as another 70 quid is a waste of money
anyway i've just been out and done about half hours worth of sidehops then got bored so decided to try a few gaps about a bike and a halfs length.
after the third one i kicked and f**king flew over my bars i thought it was the hope pro 2 (which is brand new but started to pedal and the cranks have threaded were the front ring is
anybody else had this issue with them?
Peace
Luke
Sorry to say this mate but if this is the second time you've done it it sounds to me like you are doing something wrong. How easily did the sprocket screw on?
Are the threads totally gone does the cog spin freely? Sounds simple but it might be alright it might have just tightened up when you kicked hard?
i work in a bike store so i doubt i'd mess it up! the first time it went on correctly but i was using the wrong bash as tarty bikes explained so i bought a new set and the right bash and it went on fine all the way down to the bash with my fingers i then tightened it correctly!
its spinning freely so i know its the threads that have gone!
Your f**k then aren’t you!
ye as far as being able to ride the bike goes but i've contacted the supplier who i have to say gave great service when sending them :) so hopefully i can get it sorted but i dont really want another pair after its just done that :\
sounds like you will be able to claim on a manufacturing warrenty, assuming you bought these cranks new? did the cog screw on with easy or was it stiff?
edit: i ran some trialtech cranks and they where fine i think you just got a pair with a fault on them, or your doing something wrong
Edited by basher
ye bought them new on friday :)! as said easy i didnt cross thread it! if i did that i wouldnt have a job!
Are you sure it's you're crank's which are threaded or is it possiably the 18t screw on thing.
well usually in this case the lesser stronger material loses and the chain ring is stainless steel :) cranks are aluminum
By the way this isnt a rant or complaint just wondering if its happened before?
Edited by Luke Williams!
just contact tarty and they should be able to go through the warrentie process, as im sure this will come under it.
aye its just a little disappointing i've had burns and urban legends for over a year and this has never happened before just wondering if its because its a cheaper crank?
every manufacturer produces some defective parts though hence warrenty
