Help Needed - Urgent
BTR_Vince
I'm taking my bike (MAD Phase 1.2) in to the shop to change its 8 gear speed to a single gear, what is the ratio I need? I usually ride with it in gear 3, what ratio is that? I'm not too good with the specs and things on bikes. I have to be in the shop in 10/15 minutes so all help is welcome!
EDIT: The guy was also saying something about how many teeth it must have etc.....?
Edited by BTR_Vince
Iv got a Phase 1.3 and I went to single speed and I use a 18 tooth on the rear and the standard 22 on the front. Have a look on the casset and it should say on the gear you are using what it is or you can just count.
OK I just came back from the shop now and the guy says he will get a new chain, hub and sprocket.
The chain will be a KMC chain - any good?
The hub will be a Joyteck hub - any good?
And he doesn't know what sprocket he can get yet.
Unfortunately a bike shop has just cashed in on your lack of knowledge.
All you need is a DMR single speed kit.
I see...
But fortunately I'm getting that kit, plus a new hub and chain for only £15 more than that kit. And its being done for me.
Also seeing as I'm in South Africa it would cost quite a bit to transport it all the way down here.
But thanks for pointing it out anyway.
