Double Disk Gu-st
Mission Prodigy Trials.
Hello this is my new Gu-st which I have completed today,
Pictures are at the bottom of the topic .
Spec -
Frame: GU-ST 08"
Forks: Echo Lite.
Stem: Monty 221 Kamel stem with a Pro-Bolt M6 x 30 Alloy head cap Bolt + 4x Titanium Bolts + Monty Sloping Top cap & Carbon fibre headset spacers.
Bars: Zoo riser bars.
Headset: Tensile Ace.
Grips: Richey Wcs lock-on ( Foam )
Bottom Bracket: ZHI ( Isis )
Pedals: Trialtech Sport Magnesium.
Cranks: 170mm Trialtech sport forged ( Isis )
Bash Plate: Echo Lite.
Bash Ring: Neon 7075 CNC.
Freewheel: 18T Echo SL 108.
Chain: Trialtech Lite Z610 HX, 3/32''
Spokes: Sapim Race Double Butted with Sapim Polyax Brass Nipples.
Tyres: Maxxis Cc front & Try-All Sticky rear.
Front Rim: 20" Echo TR.
Rear Rim: 19" Echo TR.
Front Hub: Echo TR Disk.
Rear Hub: Echo TR Disk.
Snail Cams: Echo TR.
Rim Tapes: Try-All.
Rear Sprocket: Echo TR ( 12T )
Tubes: Maxxis welter weight Front, Try-All rear.
Rear Brake: 2009 Magura Louise BAT 50/50 with 160mm rotor.
Front Brake: 2009 Magura Louise BAT 50/50 with 180mm rotor.
Brake Pads: Superstar components Kevlar compound brake pads.
Brake Rotors: 160mm Rear + 180mm Front Magura rotors ( Licenced by Galfer )
Neoprene chainstay protector: Tarty bikes.
Wheelbase: 1010mm
Chainstay: 362mm
BB Rise: 55mm
Centre of BB shell to top centre of head tube: 615mm (24.25")
Head Angle: 72 degrees
Weight: Unknown at this stage ..
I also want to give a special thankyou to Tartybikes team and " ZHI CHRIS " on this forum for sorting me out the frame and parts .. smile.gif
Pictures :
Thank you.
Edited by Mission Prodigy Trials.
Wow! I bet that is a big step up from the mission! I'd love to see a video of that being ridden.
It is a big step up from the mission and I'll post a video soon and some riding picture's,
I took the pictures with a 2Mp Lg Prada and a Halogen light because my flash was crap I will hopefully get a decent camera soon and re-shoot the Picture's again.
