Echo Pistons And Magura Pistons
*Koxx hydroxx 2 Jack *
My mate had this problem a couple of weeks ago when he ordered his new bike he got tnn cnc pads and an echo sl brake and the pads wouldn't stay in the slaves. They fit my magura fine though. Hes now got heatsink coust cnc pads and they fit fine. Which backings do you have?
Edited by EchoSam
As for the sizing around the piston and slave cylinders, if you're talking in mm specs, yes they are different but not so significant. The piston nipples (if that's what they're called) is slightly different shape so depending on the CNC backings you use it may or may not fit. Although like with the TNN CNC backings you just need a bit of light grease to snap them if it's tight.
ive just got some second hand cnc backings to put in my echo pistons , but they dont appear to fit . i was just wondering if he slaves for maguras and echo brakes have the same pad mount thingies , if that makes sence :P
help me please !
jack .
You've answered the question yourself. Some old Heatsink CNC backings don't fit Echo slaves. Don't know about others.
