Please Help Before I Throw My Bike Out The Window!
Sam Styles
right...
my left crank arm keeps coming loose, but the bolt is as tight as it can be, with locktight :@
when you first tighten the bolt, the crank is solid, but even if you tap it with a allen key, the crank arm becomes loose.
im really getting annoyed with this now, and im gonna flip!!!!
its been happening for a month now and i want to ride my bike with out being paranoid about the bolt :@
please help me!!!!
if u wanna get ur crank off without tool try un-doing the bolt putting boiling water on the crank then hit the crank off with a mallet..it worked for me but ive got square taper :S
but it will help to get rid of some anger (hitting it with a hammer)
Try puttin a BB spacer on but dont go so tight that you push it off. That should do the trick. My mate has this problem at the mo and he thinks he needs new cranks but in fact he used a breaker bar to tighten his cranks and just pushed the spacer off causing the wobble.
Its weird how it doesnt come off with no tool, because mine fell off one day. Ive never heard of this happening to a crank, good luck getting it fixed mate.
Mine did this, and the problem was that the arm was worn on the inside, and I had hardly rode it which was gutting. So my mate luckily gave me some spare arms and now its solid!
Get your arm off and have a look mate
People keep talking about getting the crank off with crank pullers and using mallets, but in the OP he says it keeps comming loose so surely it'll pull off easily by hand? :huh:
no way could you take it off by hand!
i will see if i can borrow james crank tool, if i ask him nicely... i think i may try the handle bar thing! that sounds really good! but not my bmx ones :P they were bloody 65 quid :L
cheers guys, im gonna see what i can do :)
i have found the problem!!!!!
right... i have found out that the bb spacer has, affectively, worn away, and left a groove where the crank arm pushes up against...
therefore, the crank bolt would have been tight on the bb axle, but the crank would still have room to move as the spacer had given it the room. this explains why the bolt was tight and the crank still wobbled.
now, i have tried grips to get the spacer off, but it will not budge, so i am going to have to buy a new bb ( just a cheep and chearfull to tide me over :) ).
right now i am in the procces of bodgeing the groove with one of my legendary cable tie bodges xD
should hopefully order a bb tonight (Y)
cheers everyone for your help :)
(i got the arm off with a hammer)
thanks guys :D
Sam
