Speed Race Fans Evo ! Update Stripped :d
JamieWilliams
Hi all Well here it is My Speed Race Fans evo Frame :) Big Thanks to My sponsors
Easy-bike / TNN engineering / TrialsDEN / TribalZine / LMG Wear
Update : Stripped frame and forks to silver ground off bash mounts Stripped and Sprayed Levers black
Spec
Frame and Forks
- Frame: Speed Race Fans Evo Black
- Forks: Try all Sprayed black
Wheels
- Front hub: Echo TR, 32h Non Disc
- Rear hub: Echo TR, 32h Non Disc
- Chain tensioners: echo tr
- Front rim: Trialtech SL
- Rear rim: Echo TR
- Spokes: Sapim Butted
- Wheelbuilds: Jamie
- Rim tape: Viz green
- Inner tube (front): Maxxis Welterweight 20''
- Inner tube (rear): Maxxis Welterweight 20''
- Front tyre: Try all Stiky 20"
- Rear tyre: Monty Eagle Claw 19"
Brakes
- Front brake: Magura HS-33 4 finger lever Water bleed
- Rear brake: Magura HS-33 4 finger lever Water bleed
- Front Pads: TNN Belaey
- Rear Pads: TNN Belaey
Drivetrain
- Cranks: TrialTech 175mm
- Freewheel: Echo SL, 18T
- Chain: Trialtech Z610 HX
- Rear Sprocket: Trialtech 12T
- Pedals: Wellgo Magnesium cut
- Bottom bracket: TrialTech sport lite
- Basring: Trialtech Halfring
Steering
- Headset: Try all No war
- Stem: Trialtech Forged with TI bolts
- Top cap: TNN
- Grips: Trialtech Foam
- Handlebars: Try-All 09
Wheelbase: 1000mm
Chainstay Length: 350mm
BB Rise: 81mm
Head Angle: 72 degrees
weight: 8.1kg
Jamie
Edited by JamieWilliams
Looks mint! :D
Where did you get that frame from and how much was it?
Thanks
Contact speed race them self don't no how much it will be for you here is there email easy-bike@hotmail.com
Jamie
Brother didn't log out of his account :shifty:
Edited by alexczar
  • 1 month later...
  • 2 weeks later...
