Cable Bust :/
Gilbert
i actually know nothing about hs33's
all i know is the cable split at the leaver
brake fluid leaked etc..
so, where can I buy a new cable, is 134cm ( 53") sound about rite?
or are they a standard length?
what brake fluid is used?
and what is it about bleeding with water?
post-29720-0-89784600-1308005562_thumb.j
post-29720-0-54821500-1308005578_thumb.j
post-29720-0-00660600-1308005603_thumb.j
yeah because i thought people run them on water, but when it leaked and it were propper brake fluid, i was bit confused, cheers guys :)
It would have been bled with mineral oil from the factory, but bleeding with water is a good 'upgrade'.
You can get olives (little brass round sleeves) from chainreaction or tarty.
yeah i got 2 olives, bleeding pipe, and a seringe already orderd..i know how you bleed them
but how do you out water in??
see im a motor trials man really, normally for me theres a brake fluid resevoir, so i just top that up, then bleed it through
but with hs33's, its just the leaver,... then pipe to the calipers
where do you/how do u get ur juice in??
You know how to bleed them, so to put water in basically you just use water instead of oil when bleeding.
