Brake Problem
trialskidy
Clean the rim or regrind.
Il try and clean it but i can't grind it without a grinder
Have you recently changed rear tyre or had it off because i put a new tyre on and its made my brake Sh*t. I think the rubber dust gets on grind or something
I changed my tyre about 3 week's ago it's been oki till today.
did you wind the tpa all the way out before you bled it?
if not then the lever piston might be bottoming out before the brake reaches full travel
edit: i have an echo lever and this happened, might be different for normal hs33 levers
Edited by err
