My Disc Brake Is "jumping".
Aii_Aitch
I recently bought a second-hand hydraulic disc brake (troll away).
I re-bled it earlier, and I've used industrial-strength wipes to take off some of the ick from the actual disc and the pads.
However, I did expect it to give a strong "bite" when I squeezed down hard on the lever, rather than taking another 5 inches to stop me.
It's like I've still got small pieces of residue on it from whatever the previous owner has been doing with it...
Any idiot-proof ways of getting the rest of the residue off? (That's what I think it is, I did take two hours to bleed the system as well as I could beforehand.)
I've been told that putting the relevant parts in a solution of white spirit will get rid of any oils?
Likelihood is that your disc and/or pads are contaminated. Don't use white spirit, use methylated spirits. Wipes down the disc with them and a Brillo pad. Stick the pads in an old clean tin of beans or similar, fill with meths to just cover the pads and light it. Let them burn a long while, then put it out and leave them to cool.
Stick em back on the bike and bed them in and you'll be in a much better position I'm sure. Which brake is it?
Okay, will do. Thanks.
It's a Tektro Gemini. I don't think it's trials specific, but it's just to make my Onza Zoot look a little bit more interesting. Means I don't have to grind the rims, too.
