Jamie Williams ! Twixtor Up To Front ! 60Fps / Adobe After E
JamieWilliams
Twixtors not supposed to be used like that, you play the clip in normal speed, up untill say your front wheels about touch the wall, twixtors designed for super slomo, so you basically almost stop the clip dead, so its barely moving, then change it back to full speed. I'd do an example but i don't use After Affects anymore.
Starts at the right place but you let it go on for tooooo long. Also the there's many other factors that affects how clean the effect comes out, maybe the 2 tutorials in this link http://philipbloom.net/2011/12/06/twixtor-2/ will gives you some better results on the editing.
But personally I'd say the footage has too much crap in the background, notice the blurring around the rear wheel but pretty much nothing from shoulders up as that area has a nice clean contrast between what's moving and what's not moving. Maybe if you took a clip where the angle of the camera shows only the sky in the background you'll get a nicer result.
