V Breaks
blip30
You can also lighten the feel at the lever by backing off the screws that control the tension on the arms. If you don't have much drag in the cable housing it should result in a easier to pull brake. The downside is the arms can move about when throwing the backend of the bike around leading to unusual sounds of momentary pad on rim.
Edited by bip
