Helicoiling the lazy way?
Azarathal
Hey guys, managed to strip 3/4 4bolt mounts at once despite being well greased and barely torqued.
Basically, won't be able to drill until after xmas due to tools being with my dad but I have the tap and coils at home, would I be able to simply use the tap to thread it? I know it'd blunt the tap quick but I'll probably buy a new kit soon anyway.
Is it doable?
How do,
I take it that you're helicoiling to 5mm? If so, you should be fine with just the tap (the tap will be M6 x 1.0 (or 0.8), so a 5mm hole to start is fine). It will take a while, and don't over do it as you could end up snapping the tap.
Cheers,
Josh.
Edit- thats if the tap IS M6 :P
Edited by Rob Leech
How do,
Cheers,
Josh.
like josh says 5mm hole is fine
just make sure you use some WD40 or oil to help cutting or you got a high chance of snapping the tap
