rotating bash ring
nickdonboy
Yes, you need to remove the cranks first. Using an impact wrench to tighten the freewheel before installing the cranks will give you a much higher chance of installing the bashring in the correct place. It'll very often rotate while the freewheel tightens during the first few seconds of riding, if you don't account for that rotation when positioning the bash you might end up with it being in the wrong position.
