Newbie question - 2 sprockets on rear hub.
tomireland
Hi, folks
I recently bought a second-hand Onza T-Bird as just starting out. I noticed that the back hub has got 2 sprockets on it, but they're on either side of the hub, left and right side, in between the hub and the chainstay. Is it normal to have a second one as I've never seen this before? One sprocket looks slightly larger, so I assume it's to flip the wheel around to run a smaller rear sprocket. Just never seen it before.
Cheers!
Tom
I'd assume the previous owner bought the wheel 2nd hand and it had the 12t on which he couldn't remove so he left it on and just put the FW on the other side. There was quite a few hub with both sides threaded like you say to be able to flip the wheel and run 2 different gear ratios.
The 12t is because the most common gearing on a 20" is an 18t FFW on the cranks and a 12t rear sprocket.
Hi, folks
Cheers!
Tom
It’s called a flip flop hub old style thing it’s from the time when front freewheels was just starting out. it’s so if you did not have the tools like a vice to remove your rear freewheel you just take the wheel out turn it round put the 12t on and put wheel back in change cranks put chain on and done your now front freewheel
In addition, it would appear that the side where the chain is, it's an 18T rear freewheel. Other side is just a screw on 12T sprocket.
Normal gearing for 20" bikes
rear 18t rear freewheel crank 22t
rear 12t crank 18t front freewheel
Edited by Earl
Thanks for all the replies, that helps clear it up. 22-18 (rear freewheel) appears to be my setup. Just wondering if freewheel could be moved to the front and then I can use the 12-T fixed sprocket. So it'd be an 18-12 setup with FFW. Not sure if that'll work though, so appreciate any thoughts.
Cheers!
22:18 will be really light as mods either run 24:16 or 18:12 but most free wheels are 18t
You're telling me! It's like pedalling into air. :) So do you reckon the 18T freewheel on the rear could be moved to the front? As mentioned I have a fixed 12T on the opposite side, so could potentially flip the wheel and have an 18:12 setup, but not sure if it's do-able or not. As you can tell, I'm vastly experienced. ;)
