Echo Press fit BB bearing - Where to buy
N.Wood
Hello all,
I run an Echo SL frame with a pressfit bb, and it seems tarty no longer stock these. Any ideas what size they are? The ones I bought from there before were Fly bikes (I think?) but can't be sure.
Seems no one sells anything for frames with less than +60bb these days, which is a shame.
Item: 6904RS Ball Bearing
Type: Deep Groove Ball Bearing
Material: Chrome Steel
Closures: Rubber Seals
Lubrication: Self Lubricated (Grease)
Dimensions: 20mm x 37mm x 9mm/Metric
ID (inner diameter)/Bore: 20mm
OD (outer diameter): 37mm
Width/Height/thickness: 9mm
Size: 20 x 37 x 9 mm
  • Like 1
