Hope Oil
Kenny--Trials
I've tried using power steering fluid, but my chemistry teacher told me it had some solvents in it, so would this somehow damage the brakes?
Also, as I sometimes ride in winter (Not just any winter but the famous Russian winter aka easily -25ºC) I was recommended to add some antifreeze to the oil. Again, is that somehow bad?
Power steering fluid will ruin the seals, I wouldn't put antifreeze in hope brakes.
Dot fluid should work fine at that temperature from what I can find on Google, might operate a bit slower but shouldn't freeze.
I did it with my Echo TR brakes (though idk if it makes any difference), and they weren't leaking more than before, with proper oil, the one that was already in the brakes as supplied by Tarty. Is it just that these levers are crap? I've had four, and all of them started leaking like three months after the first use
