Leeson 26" Frame Restoration and modification
mike425
I bought this frame used from Julius Czar on here last year with the intention of building it with a load of parts I have left in the garage from years ago. However, my other half had a baby 4 months ago and I just have never found time until recently. I bought a new clear 660 about 16 years ago from Clive and I completely regret ever selling it so this goes some ways to filling that gap.
It is not a "normal" clear 660 frame, I think it is longer and it has no seat. to be honest, I am well passed using magura rim brakes so I am adding a rear disc mount and I might just remove the magura mounts completely.
Also I am not a fan of seat less bikes so whilst I am at it I am going to add a small seat mount and run it with one.
The frame also has some dents in the rear stays I am going to fill these with braze and then sand them back so the frame will look good as new.
The build is pretty old school as I am reusing parts from donkeys years ago. So far:
Hope XC rear hub on a Sun singletrack rim
Hope proII front on a singletrack rim
Middleburn cranks.
Slightly newer but I have a set of Hope Mono Ti discs for it.
Stem and handlebars to be confirmed
Forks to be confirmed (I am tempted to go with something more modern from inspired here.)
I have made and filed the disc mount to fit, I have a small home made jig I have used before for centre and locating it. The seat post is mitred and a slot cut.
So I am hoping to braze these on and finish it this week, I will also be adding some cable guides for the rear brake hose....
Frame as it currently is:
Seat post made:
Dents to be cleaned up:
Disc mount cut to size and mitred:
Edited by mike425
  • Like 3
