12x135 single speed freehub options?
Swoofty
I know about Industry 9, Profile Elite and Hope 12mm through axle single speed hubs, but am I missing any others that are worthy of trials? Oh and I guess there's Onyx (too $$) and KOM (way too $$$). All the others I could find are 10mm bolt on only. Probably gonna go with a Hope, but wanted to see if you guys know of more.
There is a Spank that is not single speed specific but is used by Yohann Triboulat successfully.
There is a DT Swiss single speed hub, but the number of POE is low, 54 or so.
You want a freehub, right? Else you could go for a Waw hub with an 18t freewheel (that implies a 22t chain ring).
I would say I9 Hydra is the best if you have the money, Hope Pro 5 Trials if you are on a budget.
Another option would be a Canadian company called Tairin. They have a fairly high engagement point but their hubs are not single speed specific, so the flanges are a bit narrow.
I am glad that I9 supports single speed 135 spacing even if they may not sell much in that option.
18 hours ago, Alex Dark said:
Chris king ? I’m sure they’d have an axle option to suit.
They do, but they have discontinued parts for all of their legacy products so you won't be finding any hub parts to swap for.
Unless you already have a King hub, not a good idea to get one now with no OEM support from them.
  • 3 weeks later...
On 8/21/2024 at 1:57 AM, AdamR28 said:
And pretty much anything that's 10mm bolt in can be converted to 12mm through with a 12mm drill bit 👌
I definitely considered this option, but the 12mm axles on a proper hub are already so thin I figured my 'custom' attempt would only make things worse. In the end, I picked up a Hope.
  • 8 months later...
I take it back, I was looking at the older hub.
I thought Chris King was expensive
Edited by MCHARDMANUK
  • 2 weeks later...
TMS now offers a 12x135 version of their rear freehub. I've had good experiences with the bolt on version so hopefully this one is the same. It only comes in black.
