Removing Cranks With Out Tool? Possible?
cookie456_the2nd
Hi all.
Any one got any good ideas to get a crank off without damaging it too badly?
Ive lost mine (which is actually my mates :"> ) and my local bike shop wudent let me use one [...cough..pr.ick...cough..] I would buy one but i dont have any money till saturday.
So anyone got any suggestions?
just hit it off with a hammer, it shouldnt really damage it and if you give it a few good clanks on each side it acts as if it were wobbling so falls off.
You could try using boiling water to speed this up i suppose :P
proper tools all the way people.  btw, ur lbs sound like right tossers.
smithy
For not letting him borrow a tool? Why should they?
If you can hammer your cranks off, then they weren't tight enough in the first place :-. Best way is to do some light riding with the bolt off to try and work the crank slightly loose, then cover it in boiling water (a blowtorch is better if you've got one) then get the hammer out. You have to be careful riding without the crank bolt though, if the crank works loose then it will damage the taper especially if its ISIS. If none of that works there's always a hacksaw :P" (some dumbass at work had to resort to this as they f**ked the threads :P)
(some dumbass at work had to resort to this as they f**ked the threads (Y))
I fooked the threads, but all I done was get some priser bars and put them in between the crank and frame then pus against the frame, then the crank flew off and hit me in the face (Y)
Edited by terror-error
Ouch! I didn't mean he was dumbass for stripping the threads, we've all done it at some point I'm sure :D". This guy is just generally very stupid though. It took him an hour to get the crank off eventually with the aid of a hammer, blowtorch and hacksaw (Y)
