Mavic D321 Rim
dave33
the rim doesnt have a braking surface as its designed for a disc,i know danny smith done it but has any one on here got one on now?
there is a lip of around 6-8 but with an angle grinder it would be easy to make a braking surface as iv done this on an old f219 disc rim and was great (Y)
the rims are 680 grams which is lighter than a koxx isint it and thats before any drilling and im 100% that its stronger than any koxx rim,echo,onza........
i will be doing this soon when i get my rim altho i have one on the front of my santa cruz which im temped to go steal now, no better wait (Y)"
edit typo :">
Edited by dave33
No sorry I don`t no anybody that has used one. I use a D521 and they are perfect just spend that little more and get one worth the money. Get it in CD and then get some Heatsink Konigs.
You will have the perfect brake.
Gaz (Y)
Yes but there too narrow for use in most frames these days, hence using the 8mm wider 321..
EDIT:
Hmm What about one of new Tioga rims? They seem to be holding up pretty damn well for anybody whos using them in 24".
FACTORY DH 24" & 26" Rim
Double wall aluminum construction
Stainless steel double eyelets
Knurled wall to prevent tire slippage
35mm width
Disc brake only; 32h or 36h
24" 545g; 26" 590g
Black with white stripe
Only 1mm narrower than 321, same weight as a 521 loads of room for a brake and only £25? Hold grinds well apparently too, would be my rim of choice
Rich.
Edited by rich4130
EDIT:
35mm width
24" 545g; 26" 590g
Rich.
i would run one of these rims but i have £108 worth of ti spokes which would be to short to run with the tioga, but my spokes are fine for the D321 and they are amazingly strong rims!! so thats why
todge let me know how you get on with ur's (Y)
post up some pics shows that there is room for brake pads (Y)
  • 1 month later...
Hello Everybody.
I have built my d321 on the rear up and am using Magura pads on it and its working a treat :blink:
There is just enough sidewall to sit the pad on, the width is about 1mm under a Ronnie, and its much lighter (and stronger).
I have decided not to run a grind because I personally like how the CD surface works for mmy bake as its very dependable, but a grind would be easy enough.
I will get pics up as soon as my camera returns from being repaired for all to see.
Todge
i had a 321CD disk rim on back once...
its like the D521 but .... STRONGER!!! this rim is immense! i clobbered the corner edge of a 2ft brick wall once at about 25 - 30 mph with the back wheel, (hand slipped when i bunnyhopped) .... the 321cd went BANG!!!! and all it did was slightly bend the lip edge (where the tyre sits) inward about 3/4 cm ... but the dish of the wheel ect was still perfect! didnt affect the trueness of the wheel what so ever...
..i was running a nokian galla 3.0 tyre on it with an intense DH tube though... but i used to run 15 psi .... funny thing was, i didnt even get a punchure!!
i also set it up with a magura once, when i snapped me disk.... and belive it or not, it works pritty dam good!! but you only get half the pad to touch the rim, aS there isnt enough surface..
they are a bit weighty though..
