Ck Internal Headset
aaron_trials _247
good for a zero stack headset, but a little pointless.
go for a hope, near enough same quality, half the price.
they last for ever and easy to get hold of spares.
that is the biggest load of bollox i have ever read...might just be me but isnt this headset internal and a hope isnt, and plus hope headsets are shit from many experiences.
yer it should do, its basically the same as a normal headset but has the bearings inside the frame instead of outside the same as your standard headset.
an internal headset is one where the bearings are placed derectly on a notch on the frame with a cap over the top. this leads to many problems, where as integrated headsets are a decent enough idea, but a standard headset is ideal.
go to this link - here
it will download a .pdf file which explains all to you.
or you can read it online - here
cheers
ben
Edited by ben@hulltrials
i was looking at one of these for my t-rex when i had it but i think fatmike told me that they wouldnt work or somin. i think they are more for road bike use cause my boss where i work has road bikes with these headsets.
"Perdido™ is not just a headset, it is also a Standard that is free for everyone to use and refer to. King designed this new standard to make a strong headset/headtube that is easy for shops and manufacturers to work with. Reaming and facing tools are available directly from us. Frames designed to work with the "Zero-Stack" or ZS system can be converted to Perdido™ using our tools."
Certainley doesn't sound like it will fit in a standard t-rex!
And I'm not sure if they have ever, or are continuing to sell them, so at a guess, I'd say no. (Y)
