A Bit Of Trouble
cp101
Am I running too low of tire pressure when I can feel my blasted rim on drops?
Seriously. And I need a bigger tire, gdamn 2.3s. Whoever said 2.3 are big enough for everybody needs a lesson in absolutism after getting beaten..
I'm also pissed because I developed some flat spots in my rim...(dx32)
i used to run 2.35's... never had a problem.. so i dont see why you should either.... just pump the tyre up a lil harder.... your always quite harsh in the process of learning some moves... you just get smoother and better as time goes by
