Low Crank Clearance, What To Do?
stiffnips
Hi there,
I am having a little trouble with my cranks clearing my brake, i am currently running a try-all isis BB with try-all cranks on a black mumba (mod). Someone has already told me i should get a longer BB, but which BB would be the best for my money? (has to be isis) The brake is already mounted almost all the way in and the crank just about clears it, i have also had to mount it at an angle which i'm not happy about to be honest because i have just bought some new pads (thanks prawn) and i don't particualy want them wearing at an angle. So what i really need to know is the length of the BB i would need, i was looking at the new ko-bike BB could anyone tell me anything about that?
This is how far the crank is away from my brake.
IPB Image
This is how far the crank is away from my chainstays.
IPB Image
Help would be appreciated.
Cheers, Nick
Edited by stiffnips
I thin the size you need is 128mm
As for which one, (although I've not tested them) you can't go wrong with a trials specific one (echo BB, Koxx BB etc) My truvativ gigapie works fine although it didn't really fit in my frame :shifty::ermm:
I always thought that koxx bb's came in 127.5mm only so thats the biggest you could get . . ?
im running a 118mm with front fixed cog on my zona with no problems . .
and the koxx bb's arent weak
No, Try-all do three different sizes (118,122.5 and 127.5).
Mine either, but the file provailed! B)
What sise is yours, or don't you know?
It looks like you the same amount of room bewteen your stays and your cranks than i do. :ermm: And my cranks are no where near my brake cylindars, and they're right out.
