Snapped My Pashley!
somberlaine
Hi all,
It's been a while since I last posted here but I figured someone may have some sage advice for me. Basically, I have a Pashley 26 MHz (old skewl, I know) and the right hand side magura mount on the rear of my frame has snapped off.
So what are my options? Is there any place from which I can order in a new brake mount and get it welded on or does this mean getting a new frame? (I can do the welding myself so that part shouldn't be a problem). I'm poor and love my Pash so don't really want to go down this route if I can avoid it.
Cheers for your help,
Michael.
I think you can buy braze-on mounts, probably from CRC or Tartybikes but I haven't checked that so no promises!
If you cant find them then I'm sure someone on here will either bave an old dead frame that you could pinch one off, or speak to Clive Leeson (or similar) as I'm sure he could help you out.
Hope you get it sorted mate,
Luke
http://www.chainreactioncycles.com/Models.aspx?ModelID=1269 - That any good?
Edited by rideside
If i remember rightly, my mate got 4 bolt mounts welded on to his 26mhz a while back but ended up scrapping them and putting normal ones back on, the top chain stays are stupidly wide on the pash and the brake is always set really far out even when fully adjusted. Unless theres a solution to this? but not one that im aware of :) just thought id bring past experience up.... might not be 100% accurate and maybe easily solved? Good luck anyhow whatever you decide to do with it matey.
Rob.
Hi again, thanks very much for all of your help and particularly to 'trialsmad' for offering those free braze-ons.
I heard similar stories about braze-ons meaning your pads are too far apart. My rim is a rhyno mammoth XL - is this wide enough to counteract this problem? I may get back to you on those braze-ons, 'trialsmad',but for now I shall look for the 'traditional' lug.
Thanks again and I'll keep you posted!
Michael
Yeah, getting a rear disc would definately be a last resort, lol; the fact that my preferred currency at the moment is Tesco computer-for-schools-vouchers shows you just how poor I am :P>_<
So just to double check, is it possible then to have new v-brake mounts re-welded bake onto the rear of my frame?
Michael
