New Brake Or Rim?
Jason
My back brake (raceline magura, on my t-pro [05]) doesnt seem to reach the rim. Its just an old onza rim, and I'm thinking of buying a wider one. But I'm also thinking about getting a new back brake instead, because this one seems nackerd, its just had a fresh bleed with my lbs, but doesn't seem to go out very far even with the tpa up full <_<
any suggestions?
They might not have bled it right.Did the wind the tpa towards - before bleeding it.
That could be the problem.How far do the pads come out ? go and mesure .
Thanks
Deonn
yea they said they did. the pads come out like 9mm :blink:
Why dont you just move the cylinders in? Do you know how to set up breaks properly? If they are moving 9mm thats fine.... they should be set up so they are around 2mm from the rim.
Yea cylinders are right in, I'll get some pics up tomorrow when its light.
