Ck Fun Bolts.
trialsalot
hey peeps.couple of questions for you all who run chris king fun bolts.i run a rohloff tensioner with fun bolts in my ck...you may be able to see where im going with this.everytime i wanna put my back wheel in or take it out ive got to take off my tensioner.any ways round this?also...every time i tighten up my wheel using the bolts the wheel moves :S thing is when i got them the teeth on one end of the hd axle looked crushed,ive used it now though so i cant prove to the shop that they were already like that when i got it.any ways round the wheel moving?it done my nut in yesterday thinking my wheel was dished wrong.
any advice would be greatly taken in hand like 2 big soft lovely chebs,lol.
cheers everyone.
Yeah, just take the fun bolt all the way out on the mech side..
edit: when you put the wheel back in, sit on the frame put push it in the drop outs and tighten it (Y)
as for the crushed axle end, a big chunk of mine has snapped out off my hd axle, it's ok though, but not covered by warrenty.
Edited by member1495
lol,um.....no.cheers for trying to help but a proper suggestion with a safe answer to the problem would be magnificent.as far as the mech idea goes i'd have the same problem removing the wheel.i aint sacrificing my rohloff for gears...no way!it works far to well.
I grind with the tyre on ;) Just hold it back with one hand, have to watch your wrists though :mellow:
Oh my god.. for your own safety and so that i can sleep at night. Please take you tyre off in future and do it properly.
its just that if i unscrew it so the all the thread is still in the axle i cant remove the wheel because how fat the bolt head is.the threaded part of the bolt is way fatter than the width of the drop out.its a total arse this one. :blink:
I don't see any problem... I just screw bolt in with tensioner on a bolt already and then just put wheel to the frame. This is the problem with which you are struggling?
You can always set wheel in dropouts... just takes a bit more time... Filing isn't solution imo.
so instead of mounting the tensioner on the dropout you mount it on the fun bolt itself?
i think there is a bit of confusion and he thinks you have a fresh products style tensioner.
but with a rohloff, yeah unfortunately i think you just have to keep undoing your tensioner. A hassle, but its only one bolts and when you have set it up once, it will only need bolting on again and it will be in the right position. looseing and tighting a bolt doesn't take that long, does it?
Hell thats what the frames for, holds the wheel good and proper :D I have to admit that i grind the same way, let the tyre down, hold it back and grind the rim. :$
Though i have found if i grind a rim without a tyre on thats not in my frame i still only hold the grinder with one hand.... i'm too clumsy with two. :(
