Avid Bb7
planet-x-boy
Hello, I have had a cable disc before and it felt ok but it seemed harder to pull the brake lever with it being cable. I am thinking about getting an Avid bb7 but i dont want it if it is hard to pull the lever.
Any help would be great (Y)
Brett....
Hands down a 205 avid is the best brake i have ever use, screw off every other disc ever made and use a 205 avid, there so simple to set up, feel mint, cheap as chips, and are a bit good.
I have heard they are beast BUT i just want to know if the lever is harder to pull in with it being a cable. My old cable disc was good but was hard to pull in, thats why i changed to hydrolic (sp).
Brett......
Brett......
buy some decent cable (odyssy linear slic) and lube it . set it up with a lighter spring tension
Edited by leedstrials
Ive got a 160 on my mod, with a Avid cable, and Avid Fr-1 lever and its ace.
It feels easy to pull, bit like a new Magura. You can adjust the spring tension at the caliper, but i think you won't need to.
I hope you mean a new magura bled with water! I had forgotten how crap the oil is till i felt a new one yesterday.
Dont get avid flakjacket cables btw, they sux0r.
Oops, i mean dont get straight jacket, theyre rubbish, get the flakjacket if you can afford.
Edited by Hobnobs
Get stronger fingers! A new Magura, untouched by silly water is cush.
And i've got a Avid flakjacket cable. Really smooth, but it just needs to streeeeeeeeeeetch.
Brett next time your in northallerton riding have a go with mine...... ive found mine to have awsome lock but feels spoungey, my 160mm felt solid but whenever i run a 185 mount it feels shit :S
joshywa
They are amazing. I used an XTR lever with bog-standard cable and I had no problems at all. Posh cables are for tarts I reckon :P They don't really make any difference to the power of the brake, they just make it feel a bit nicer to pull.
