How Tight Is 5nm?
ghosts_cloak
Hey guys! I have my new Hope stem now :)
Being the non mechanically minded person I am, how tight is 5NM for the handlebar screws? I just did them up fairly tight with the allen key long ways (so I couldnt put down much torque) and it seemed fine, but I thought Id make sure on here?
Also it says to grease the threads... now I dont have any grease but I could put some finish line chain lube on instead?
Cheers!
Gareth
ps: It rides excellent now, much better control! Felt like Felix hopping on upturned crates on the beams (nice and smooth, for me!)
You can put the lube on as a short term solution I think, but grease is much better. Well, the equation for torque is: Torque=ForceXRadius. In other words 5=ForceXRadius measure the length of the allen key and calculate the force you need to use. To put it into perpsective under gravity a one kg bag of sugar produces a force of roughly 10 Newtons (9.81....Newtons if we're being pedantic). Radius is measures in metres so if it's a 10 cm alen key: T=Fr
5=FX0.1
F=5/0.1=50Newtons, about the force to lift 5 bags of sugar. (Y)
5=FX0.1
Hey :)
Hehe nice reply! Right up my street so to speak, Im a second year physics undergraduate, currently studying for exams! I didnt think of actually working it out, I was more looking for a "pinch it up, and then an extra quarter turn" or something, but I can see what your getting at!
I will stick some lube on in the short term then and when I get chance Ill get some grease.
Thanks,
Gareth
Edited by ghosts_cloak
A 2nd year physics undergrad should know that there isnt really anyway of translating 5nm into a force applied by one's arm.
Just tighten it up nice n tight, hope are good quality, you wont rip the threads out unless your the incredible hulk.
remember though, that 5Nm gives a higher clamping force if the threads are greased/lubed. because less force is used to overcome friction, and more to tighten the bolt itself...
Surley that would only be the case if the threads were so fuct as to require a force close to, or above 5Nm? If it only takes for example, 2nm to move alubed nut on a thread, and 3 to move an unlubed, ultimatley the 5nm is still going to hold the bolt on the same, lubed or unlubed........
It would just make it harder to screw on in the first place, and you might think that it's holding when it's not, but that would be if the thread were totally jacked.....
It makes quite a big difference in clamping force actually.
It's not that relevant on bikes, but more of a big deal in airplanes for example.
A lubed thread generally speaking gives a higher clamping force than an unlubed one, both tightened to the same torque.
:S:S:S
they are poo, thats the worst bit about them!
u need Stainles steel bolts, 50 p each but well worth it
I dont quite follow your argument there Im afraid, I was looking for a rough estimate such as:
1) Screw it up real tight, tight as you can!
2) Just pinch them up!
3) Tight as you can with two fingers
Etc..
Yes lots of variables but you can get a rough idea!
Good point about the grease /oil, they did kind of screw in "in steps" rather than a smooth motion so its hard to tell just how tight they are, Ill sort it now as its such a nice evening :)
Thanks for the replies guys, even if we didnt establish a definative "tightness".
Gareth
(Y)(Y) Excellent, thats the kind of thing I was looking for :P
Gareth
