Hooks On Walls
bikerben
Well seeing as you ride a mod that will make it harder but when i was watching my mate trying to learn at the start he just tried to hit the wall as hard and fast as he can then try and pull it up, which didnt work.
What he does is he pedals up to the wall (going quite fast) lifts up his front wheel then hops onto the wall with his front wheel ontop at a slight angle. Depending on what foot you are, if you are left footed you should be hitting the wall at a slight angle to the right so your pedal doesnt hit the wall. then stretch your arms out as far as you can possibly go then hope to hell you make it
Im sure someone who can do them will explain for you. Will take a few weeks of practice to get the hang of though.
Ewan
Edit: Try getting about 7-8 pallets stacked up then get an extra 1 then put it leaning against them at a slight angle if there are no decent walls, quite a good thing to practice on if you have alot of pallets
Edited by Ewannnn
When you hit the wall you want your shoulders to be at least directly over the bars. It's hard to explain - I've only been hooking for a few months myself. It's as if you're trying to do a running dive over the wall, hit hard and fast as you'd expect but lean the hell forward.
