Snaped Teeth On Rear Sproket
3rider3
I did this to my Eno freewheel...it made links in my chain stick as if they were still on the cog...like they seized up bent :S hard to explain..didn't do any harm i don't think but it is better to replace the cog as the chain hasn't got as many links in contact with teeth at a time..im probably talking out of my arse because i am tired.
zoo baby!
Edited by zoo
the sprockets just screw on. but because of the fact when you kick it tightens the sprocket on more they are really tight on and can be hard to get off. first of all you can try a chain wip and if it is to tight on try heating the cog to expand the metal and use the chain wip then when it is hot. other wise just give it to a lbs to do. you could use a metal tube on the end of the chain wip as leaverige.
