Stripped Stem...
T-BAD
Some info on how to do it found on google:
http://www.toolsnextday.ltd.uk/Helicoil_Ki...icoil_usage.htm
The same place charges £25 for a kit (Part No. 35050, M5 x 0.8 Pitch). Worth shopping around!
http://www.toolsnextday.ltd.uk/Helicoil_Ki...licoil_kits.htm
Loads of places you can buy the kits from in the UK, just have a look on google. There are lots of these kits on Ebay I notice. Potential to save a bit of money there :)
Check that the outer diameter that the holes will be drilled/tapped out to is not going to leave an unreasonably thin outer wall.
Helicoils are stronger than the original holes tapped into the Alu. From stripped thread to better than it was originally - Result!
Steve
What about:
http://www.knighton-tools.co.uk/acatalog/M...epair_Kits.html
Also, available from RS Components:
http://www.rswww.co.uk/ - Enter component code: 528-592
Steve
the latter of them links are out of business me thinks steve, i have tried to ring and the number doesnt work.
hmm ill try shopping around.
ta
