Which Magura Brake Pads
Rupertbear
I got some heatsink coust pads. There are very good. I run alittle grind just done with a knife ;)
They are a soft pad because ive taken my bike apart to spray it and I cleaned the pads and they feel softer than most pads (Y)
|Matty
I have allways used Magura reds... or Magura Blacks.
and I have never had a masive problem because of my pads.
I wonder how would it brake if I had good pads.
When I went from normal magura pads to heatsink coust I was AMAZED :P I recommend you get some :D
|Matty
i've used echo red's and zoo pads but they wear out too quick (My green zoo pads lasted no more than two weeks):(, on a grind anyway.
so i have been using koxx browns for the last 2 months and they have hardly worn atoll. So thats what i recommend on a grind.
But do a search because there are many topics about brake pads (Y) Hope this helps :D
