Cracked Frame!
Onza-Trials
if the break is on one of the welds it wont make it weaker
but on the tubing it will, but not much, metal is metal, and it aint soft, get it welded, grind it down n itll ride! just make sure you go to a decent ally welder
If your frame is cracked, you get it welded. It still used to be cracked, therefore it will be weaker, my friend had his frame welded twice in the same place, then it snapped again in the same place and another area, re-welding makes frames weaker.
