Drop.
hi all, i live round newark area and theres this place with about a 5ft drop on grass and iv just got the hang of dropping and i was just wondering shall i go for it or not.
cheers jake. (Y)(Y)
I'd just work up to it gradually.......do a 2ft, then a 3ft etc, build yer confidence first ' cos it hurts like hell if you bottle out halfway off! :lol:
dont wheelie off that is sketchy and is very easy to have a bad landing which could lead to an injury, always wear a helmet and just do it when you feel confident enough. (Y)
seems i have posted this twice. oppssss :(
Edited by monty221pr
What's your technique for drops?
When I started, I just pedal-hopped off everything, which is very sketchy...
When you're at the edge, drop the front wheel down, and tuck back, then drop off it, straighten yourself out in mid-air, then compress down when you land.
As you have just got the hang of dropping i suggest that you gradually work your way up to bigger things. This is so you get your technique right, this is because your technique will gradually change as you get onto bigger things.
I know people less than 5ft, i'd only do it if i knew i was confident enough, try standing up there without the bike. I used to do that and found it helped. Dont go too big too soon! and wear a helmet!!
GOOD LUCK!
thanks mate o yh and i just orderd a helmet lol
cheers jake. (Y)(Y)
Listen to this guy thats good adice and the best thing to do.
Good look if you decide to do it.
Sam
