Sidehoping
1337 Trials
True, I often think this but what is the best way to sidehop??? IM thinking like doing the one backhop and kick then laugh myself up :)
~Matty
Laugh yourself up? That would be impressive! Hahaha... Oh shit I'm up!
Need to work these out myself again at the minute, but as has been said, a lot of it is just the commitment.
Use the search and you should be able to track down a fair few topics on it, with a decent amount of useful content out there on the rest of the net too :)
If you sidehop to your bad foot side, then if you slip in most of the cases you
will fall down on your crank/pedal and there will be no damage to the frame.
Also practicing on wood helps a lot, as it won't bash the bike compared to
concrete.
concrete.
Cheers bud, I have tryed hoping to the bad foot (hoping left) but it dont feel right :( Well I practice on concentrete but its only 3 bricks high :) I think ile work on pedal ups for now, I feel alot better doing them , lol.
Thanks for the help-
~Matty
I've just started to sidehop. I can get 3 and a half pallets at the moment but I seem to be getting better every day. I can nearly tap aswell and I can now gap to front.
Sweet :) WHen you tap do you have a quick run up then tap or can you do it by pedal uping???
~Matty
My progression was a bit like this in the last couple of months. I could never get my head around side hopping from the rear wheel as a first attempt.
- find a low wall/bench etc and slowly roll parallel to it. Grab the front brake, do a small endo. Use the momentum of you coming down to onto back wheel and follow through by lifting the front and then the back wheel whilst going to the side. I found I could concentrate on moving sideways more since the lifting part was pretty much taken care of. You will probably jump backwards as well but this will sort itself with practice.
- Next was 2 wheels static side hop. Its easier to balance on 2 wheels if you turn the front wheel into the object you are trying to side hop. Commitment is key and if you bail you will easily be able to dab and save it on small stuff. Just have another go and get a feel for whats happening. This time your balance is taken care of whilst again concentrating on height and direction.
- Progression to one wheel side hop was a bit harder but you already have the basics of direction and height. You now need to add balance and control. The way I did it was by accident. I was on the back wheel, parallel to a ledge with a howling cross wind. When I hopped it was wind assisted and landed it. Something clicked and managed to repeat it with no wind. Just need to work on control and increase height etc but well chuffed with progress.
Hope that helps getting to one wheel.
