Freewheel
If your on a budget go buy an ACS claw there usually prety reliable + cheap if they go boom. I'd suggest buying an eno or tryall, their both expenisve but there uber good quality, especially the eno because you can replace all the components if you manage to kill anything on it (Y) the tryall just has awesome engagements 108(which is more engagements than everything else on the market), meaning you get an engagement every 3 degrees although a few people have had problems with them skipping like a bitch. If you've not got the budget go for a tensile, there awesome value + such.
Edited by ogre
Acs for the rear because won't the others come loose on the back?
no, the koxx has the lockring at the back doesn't it :S so it can't undo, and the eno is magic*+doesn't undo** (Y)
*not all eno's are magic
**some will undo or come loose
Simple if you want to be safe and not have serious problems and injurys when you are riding DO NOT BUY A ACS FREEWHEEL pay your money and be safe ,I mean do really want to gamble your health and pay less or would you pay your money and have super engament and many many points of engagement and 9 pawls rather then 4 and ride safley without face planting some thing.....its your choice......
Never had a bad acs to be honest plus he is using it on the rear :)
if you dont want to spend loads go for an acs or a tensile if your rich... buy an eno :P
mike W
i have had a bad one because it slipped and i face plantted the wall so i would'nt recomend an acs free wheel. try and get a tryall :rolleyes:
mark
Hi
was that a ACS welded may I ask ? as I had a standard one and that keep skipping because the lockring came loose all the time. But then I bought an ACS welded and I ran it for about 2 months and didn't skip once. I have a Try-all at the moment and i'm loving that so I agree , get a try-all.
Nile
Hi
Nile
i had the unwelded one and had the same problem so i got a welded one but it soon started to slip i run a profile and its great but me mates got a tryall and he ahs had no problems :rolleyes:
mark
mate i would really recommend switching to front freewheel, may cost a bit but it gives you a decent gear ratio
speaking about freewheels id say go for a tensile but if you've got the cash you cant go wrong with an eno
either way stay away from dicta's...mine lasted a record of 5 skiphops! :lol:
