Front Taps
Im just wondering what the best way to start learning these front taps are. Im at a height now where I get unwanted front taps and they put me straight on top. How did you learn to do yours?
how is it UNwanted if it puts you on top? as for learning taps, all i'm saying is Hans Rey. (NO WAY)
I dont plan on front tapping, nor commit to them. As my front wheel goes up it might clip the wall and even thats noticable. I just want them to be more consistent
You saying they're not the best thing to do?
just learnt to front tap yesterday on some oak logs. hit them about 2/3 of the way up and then pulled up, makes it so much easier. Now i just need to do the harder thing and start doing it on something vertical
2/3?? thats pretty low?
It is indeed, I personally would try to aim with the centre of the front wheel to hit about 2-3 inches below the top corner whilst learning. I would also advise that you don't learn on a sloped wall, it is bad practice as you learn to rely on the bounce of the rear wheel hitting the slope to get you up rather than the bounce from the front tyre. It may seem scarier to learn on a vertical wall but if you find a wall about 36-38 to learn on you should learn it fairly quickly.
edit, When learning use a wall that has something behind it, grass or whatever so you don't have to keep your front end up.
Edited by kenzo604
